I wouldn't call that slightly above horizontal. Ideally the shaft should be exactly horizontal, but one or two degrees above is better than one or two degrees below.From your Grundfos extract the new instalation ie the pic Ive attached is correct. The silver vent screw is facing upwards slightly. Do you agree?
the pump used to sit on its back, the big silver screw and Grundfos face palte with all the spec facing the sky.
Or that it has hot water running through it?
The pump is cooled by the water.
If its way too hot to touch then its seized !
See the FAQ on this site for how to possibly get it going.
Tony
