I have a leak in the bottom corner of velux window and when I’ve taken tiles off the soakers are pinned directly to the battens and tiles over the top I assumed that soakers had to overlap each tile, and the apron goes over the top of soakers not underneath??
No its wrong. At no time should any weathering elements lower down the roof, sit above those higher up the slope. Plus, there is not enough lateral weather on that joint. Looks like that first abutting slate needs to sit under the apron flashing. Nor should there be holes in the soakers.
Yes exactly what I thought and I think this part is my issue, the soaker sitting under the tile? And that area is damp where I’ve had leak soaking into rafter
Possibly yeah on this side it doesn’t drip into the eaves it just soaks the rafter completely, will then dry and go again when it rains, is the best possible thing for now to try and put the apron underneath the soaker?
I generally don’t know why I did that considering one was already going haha. I basically took loads of slates away starting at top and all the soakers were like that on the beam and when it got to bottom it just tucked underneath. I took the bottom soaker out and put a tile underneath laid the soaker on top of that then was able to slide the apron underneath the soaker. No ideal I know and not the right way to fix it but fingers crossed nothing leaked in and when come to re roof in next few years it’ll be done right.
