Thorn Back Boiler Blowing Fuse?
Discussion in 'Plumbing and Central Heating' started by smarty, 17 Sep 2013.
  1. smarty
    smarty
    20 Mar 2006
    48
    Thanks Received:
    Country:
    I am going to get this boiler replaced very soon, and sod's law it has just started to play up. The boiler was wired up wrong, but in 2008 with excellent advice from D.Hailsham on this forum I wired it correctly.
    http://www.diynot.com/forums/viewtopic.php?p=1031849#1031849
    It has worked faultlessly until this weekend. I first tried using the central heating, and I heard a loud pop from the boiler area and the fuse in the fused spur that provides the live to the boiler blew. This spur has a 5 amp fuse fitted. I replaced the fuse and now it is blowing regardless if it is hot water or heating selected. It is always accompanied by a loud popping noise from the back boiler first then it goes. Obviously the boiler is going to have to come out as I have read about burned wires etc. I just wondered if anybody has any idea what could be causing the loud pop noise from the boiler area. It is the only noise I can describe it as.
    Thanks for any help, the boiler is a Thorn Housewarmer Epic. The boiler was last serviced in October last year.
  2. Sponsored Links
  3. Homesafe
    Homesafe
    12 Oct 2007
    6,299
    Thanks Received:
    398
    Lancashire
    Country:
    You havnt got rats or mice chomping the cables have you?
    You really need to get an RGI TO LOOK at it.
    Get it serviced at same time.
  4. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
