thorn olympic no c/h or h/w
8 May 2005
Sheffield
i have a thorn olympic heating system. was working fine but tried to put on the hot water and the boiler wont fire. pilot light is fine any help appreciated.
is the boiler stat turned up?....is it a model with a fan or natural draught flue?
its a natual draft flue. its done this before and then started working again.
well as long as you have power getting to the boiler and the fuse isn't gone and it has been working for a while and nobody has fiddled with it it will be either the boiler stat or the gas valve. Do you have a multimeter?...you need to check boiler stat is making a switch and that you are getting 230v on the gas valve.
