When fitting our new oil central heating system we were stuck for a location for the tank, as there is only limited space at the back of the house. After some advice we converted a small disused out-house to house a 1300 litre vertical tank, but to allow for filling this had to be kept as low as possible, meaning that the take off from the tank is approx 35cm below the level of the burner on the boiler in the house. To overcome this we were told that a “Tigerloop” was required.
However as the oil level fell close to the burner level we started having problems with the supply, which failed and were told that air must be getting into the system. The plumber tried to sort it out – seemingly by smearing some form of sealant over most of the joints, but a few days later it failed again.
We now have a local firm of specialised heating engineers in to sort out a number of problems with the system (which is all new and these have been outlined in another thread). However when it came to the oil supply, the engineer has told me that a Tigerloop cannot overcome the difference in heights and that gravity is required to feed the boiler, so before he can re-start the system I have had to fill the tank.
Is this correct? Was I misled? Does this mean that the last approx. 200 litres in the tank is unusable and I will have to fill the tank before it gets below 25% full?
