Tile finish around a bath
17 Apr 2007
I've removed the trim because it was badly cracked and mould was creeping in underneath.
Are these trims still available or is there better ways to finish tiles down to a bath's edge?
full
I don’t like them personally, good old fashioned silicone seal for me.
No, it seems the strip rolls aren't too well liked - they don't stick very well.
Main issue I have is that the long side of the bath is not quite parallel to the wall with about 5/8" gap the the front, a 1/4" at the rear, which the old plastic trim sealed up nicely. Tile grout wouldn't fill the gap so really needs a new trim if I can find one.
Should still be able to achieve decent results with silicone. Post a photo and I should be able to advise better
I did attempt to fill the gap with grout but I'm not happy with it.
This is the gap at the front.
full
This is the side of the bath, lower tile row removed. Rear/front tiles and trims are still in place.
full
Short answer is no that type of trim is for the external corner of a tiled wall.
Can you replace the removed tiles??? or fit new tiles??? then fit a quadrant half round, this half round will cover a gap between the tile and the bath and when fixed with a mastic the trimming of the excess mastic very, very simple??
I get what you mean. Are quadrants available for tiling or do I get a wood length from a timber merchant and paint it gloss?
I did originally plan to reuse the old tiles but four broke and chipping the old grout of the others would probably crack them.
Do you have enough clearance space behind the taps for a quadrant tile? Even if you do you might need to remove the taps so that you can silicone them (the quadrants) properly.
Personally I am not a fan of quadrant tiles, particularly when used on plastic/resin baths because of the flex.
You mention that the worst gap is 5/8ths (1.5cm)- that is massive, especially if your tiles are, for example, only 6mm thick. Assuming that you don't want the hassle of removing the bath and re-tiling the whole room, I guess you could let the replacement tiles "kick out" at the bottom so that the required silicone gap isn't so big.
I would recommend against building up layers of silicone- silicone doesn't like sticking to cured silicone. You can get fairly decent results when working with large silicone joints if you use something like this Fugi silicone profiler. Given the size of the gap, you might want to use masking tape as well if you aren't terribly confident.
https://www.amazon.co.uk/Cramer-Grouting-Silicone-Profiling-Applicator/dp/B07H8K5W8D
Cheaper alternatives are available via the likes of screwfix etc.
When working with silicone, mix a little washing up liquid with water to stop it sticking to your fingers/tools. Clean the area with meths first to de-grease it. The washing up liquid contains silicates so don't let it get on to surfaces not yet siliconed.
