Tile gap 2.5cm
15 Jun 2009
Hertfordshire
IMAG1110.jpg We've removed a work top and where the base was , there is now a 2.5 cm gap between the floor tiles.
Can I just put grout between the tiles? (I know it won't look great but tbh we're looking for the easiest solution rather than making it perfect.)
Ok, thanks for the advice. A friend suggested mixing cement and kiln dried sand - do you think that would work?
probably not the best mix, as kiln dried sand is very fine you would be better off using something a bit coarser, like river sand and grit sand.
If you can source a couple of the same tile then lift all four cut tile pieces, and replace with a matching full tile and a full border off-cut.
