Tile size to use for bathroom see dimension
26 Aug 2007
London
Hi All,
I have some tiling questions to ask, please kindly comment.
I have a family bathroom which is 1700mm depth/leigth as you go in, and 2400mm wide and height of 2400mm. I would like to tile the floor and walls, and was wondering whether a 300 x 600 tile would be a good choice ? I would like to create an illusion of space.
I also have a master bedroom ensuite which I will be using thesame tiles for to avoid wastage, length is 1700 and width is 2000mm with a height of 2400mm.
I also have a utility room which is a square shape, 2000mm x 2000mm. The utility room houses the boiler, has a toilet and a worktop/small sink. Is it better to tile this to say 1800mm height from the ground, that is not tiling to the ceiling.
Thanks in advance.
