    Dismiss Notice
Tiles onto MDF ?
Discussion in 'Tiling' started by newboy99, 22 Sep 2012.
  1. newboy99
    newboy99
    10 Oct 2010
    19
    Thanks Received:
    Berkshire
    Country:
    Hi guys
    I need to run a small 2" / 50mm band of mosaic tiles around a bathroom at mid wall height.
    They're only 7mm thick vs 10mm for the surrounding tiles and after a few unsuccessful attempts trying to 'pad' them out with adhesive, I'm going to need to stick some 3mm MDF strip into the gap before I tile so that everything lines / levels up.
    Quick question :
    can I use standard tile adhesive for the mosaics directly onto MDF or am I better off using something stronger such as the Evo Grip that I'll be using to attache the MDF to the plaster ?
    Many thanks
  2. Sponsored Links
  3. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,627
    Thanks Received:
    2,382
    Londonderry
    Country:
    Why don't you use 3mm plywood?
    It's not good practise to apply tiles to MDF.
    If you do, you will need to contact the adhesive manufacturers, for their recommendations on priming for their adhesive or you could encounter problems.
  4. newboy99
    newboy99
    10 Oct 2010
    19
    Thanks Received:
    Berkshire
    Country:
    Thanks.
    I looked on B&Q's web site but couldn't see any plywood as thin as 3mm, only hardboard.
    I'll see if I can see any 'in store'and get it if I can.
    Other than that, sounds like I should use Evo Grip rather than tile adhesive.
    Thanks again
  5. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,627
    Thanks Received:
    2,382
    Londonderry
    Country:
    Might not get it from B&Q or their likes, better off at timber yard/merchants.
    • Thanks Thanks x 1
  6. tictic
    tictic
    6 Oct 2009
    1,419
    Thanks Received:
    173
    Glasgow
    Country:
    Dog tooth.....them....
    Google.....?
    • Thanks Thanks x 1
  7. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,627
    Thanks Received:
    2,382
    Londonderry
    Country:
    You could also as above dog tooth (render rebate to correct depth for taking the thinner tiles)
    google "dog tooth tiling method"
  8. newboy99
    newboy99
    10 Oct 2010
    19
    Thanks Received:
    Berkshire
    Country:
    Thanks guys, that looks like the way to go !
    Will have a trial run in the morning.
    Thanks again both !! :LOL:
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
