I'm about to start refurbing my bathroom and have a few questions.
The bathroom is small approx 2.0m x 1.7m.
There are two layers of wall tiles applied on all the walls currently and I have already removed a small test area, which invariably removed chuncks of plaster back to the breeze block in places.
Given the fact that the plaster looks as though it will be badly damaged when I remove the rest of the tiles I'm planning to strip right back to the breeze block completely. Or would I be better leaving whats left and having this re-plastered?
If I go the plasterboard route would I fit via dot and dab or would it be better with plugs and screws? would you use an aqua type panel around the bath (planning an over bath shower) Does the aquapanel mean I don't have to tank around the bath area? or would it be more economical to just plaster board right round and paint a tanking paint/sealer on the the bath area?
I'm planning on some floor tiles too. The floor is concrete but I'm not sure on how level this will be until I pull the old tiles up. If floor is level can I tile directly onto the concrete, or do I need to seal it with anything first. I do not want to tile on top of the old floor tiles as these have been put in v badly (cut around the vanity unit for the basin and also cut around the toilet etc)
I have a second toilet shower room upstairs which I can use giving me a good window of time to do the works.
Many thanks,
Many thanks,
