Further to my earlier posts, I'm now trying to tile the other side of the bathroom.
To do this, I've had to remove the existing tiles that were on the wall - not an easy job and as the walls were plasterboard there's a few holes developed where, when I've pulled the tile of the wall, some of the plaster has come off with it.
A few queries:-
Pic 1 below:- The two walls shown are (a) pink matt paint with glitter gloss applied, and (b) gold metallic paint. Can I use pva primer on both these walls to give a surface that the tiles (a combination of 1 inch square mosaics and 6 x 4 inch ceramics) adhesive will then adhere to?
Pic 2 below:- What is best to fill the (big) gaps in the wall - try and build it back with tile adhesive, let that dry and then sand smooth, and then tile?
Pic 3 below:- The wooden battens have obviously been installed to allow/support a lipped bit of tiling to come out from the wall at the head of the bath. When stripping off the existing tiles, the wooden battens had a sheet of plasterboard screwed into the them, with the tiles then sitting on the plasterboard. Question for this one is, do I need to use plasterboard before I apply tiling, or can I apply the 6 x 4 ceramics directly to the wooden batten (i.e. top and bottom of the tile would sit against the top bit of wood and bottom bit of wood, with the back of the middle of the tile exposed in the cavity behind)?
Pic1:-
Uploaded with ImageShack.us
Pic 2:-
Pic 3:-
Uploaded with ImageShack.us[/b]
A few queries:-
Pic1:-
Pic 2:-
Pic 3:-
