    Dismiss Notice
tiling wall same size as tile
Discussion in 'Tiling' started by Gassaferob3, 29 Mar 2020.
  1. Gassaferob3
    Gassaferob3
    26 Oct 2012
    197
    Thanks Received:
    6
    London
    Country:
    Hi
    I'm tiling the understair toilet and have a small wall that i need to tile.
    the wall is 630mm wide and I've got 300 x 600mm tiles, how can I cut these to make it look nice?
    Will I need to use two tiles per row and have loads of off cuts?
  2. Johnny Allround
    Johnny Allround
    27 Mar 2020
    459
    Thanks Received:
    88
    Country:
    You could use the 300 as the width and have a 10 mm bold groutline across perfect fit. Also you could have a feature colour grout scheme to contrast the tile colour. Just an idea as I haven’t seen the space you have.
  3. Sponsored Links
  4. Gassaferob3
    Gassaferob3
    26 Oct 2012
    197
    Thanks Received:
    6
    London
    Country:
    Never thought of using bigger grout lines. Thanks.
    That's kind of what I did, I made some paper template of the tile and cut it in half, and that seems to look OK.
  5. Stivino
    Stivino
    11 Oct 2006
    3,454
    Thanks Received:
    373
    Midlothian
    Country:
    If you have enough, could you cut them to 313 and use two to a row putting the cut edges to the walls?
  6. Sponsored Links
  7. Johnny Allround
    Johnny Allround
    27 Mar 2020
    459
    Thanks Received:
    88
    Country:
    Also like Stivino said and run an angled bead down each corner to complement the tile colour.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
