Hi
I want you to imagine the following room. An internal lathe and plaster wall 5 metres long with an brick wall 4 meters long backing onto next door, at a right angle to the first wall and finally a third wall, exterior made of stone, forming the sloping side of a tiangle between the first ywo walls.
Now, I am going to lower the ceiling and I thought I would attach a perimeter frame using rawbolts into the wall. First question is can these be used on Lathe and plaster.
Then I was going to use joist hangers to form a network across the ceiling, but I now realise that I will not be joining two parallell edges - what will be the best way of fixing the joists across the ceiling?
I hope you can help
I hope you can help
