Hi all
After an issue with the wall kit for my extractor which is now sorted.
My friend who's just started training to be an electrician ( his dad who's fully qualified signs the work off he does )
Has done the wiring , I know bits myself so helped with the run of cables etc.
We aren't having run off the light pull switch as we don't want to waste leccy
He's used 3 core and earth.
He's put a fan isolator above the door and took a l/n/e feed from the light circuit in the loft , then gone to the isolator.
Earth is in a wago in the back box , then the 3 core over to a pull switch which has com, l1, l2.
He's wired one live to the the com, then that goes out the L1 to the fan (for switched I presume) on the L .
Then the next live is in a wago within the pull switch and goes to the T on the extractor for permanent live when the pull switch is off , then the neutral in a wago straight to the N on extractor,
Fan works no issues but the timer function isn't.
Is his wiring correct as his dad can't get round for a few days , he's not well so it might be longer.
His dad won't listen to an explanation he just likes to look and sort it, and then tell his son what he's done wrong.
His son can come back but I just want to know what he's wired wrong
Cheers
Cheers
