Well, any installation with which you are not familiar - customers.I'm not sure I understanf this "lot of cases".
I'm sure that in a property such as yours you cannot be certain that there is nothing that would be making the pipe extraneous.There is surely only a need for bonding if any of the pipework (or things connected to it) 'exits' the property.
No, not with regard to main bonding but that's not the point.If there is a gas supply, then there will usually be continuity between that and the water pipework (e.g. at boiler), but provided the gas pipe is properly bonded, that would not, in itself, create a need to bond the water pipes, would it?
You must be certain that the water pipe is NOT extraneous itself.
