Hi All,
My parents have just bought a house, and on my first visit, I had a look in the meter cupboard to get an idea of the state of the wiring. There are some things in there which are criminally bad, and need very urgent remedial action (such as some 10mm T+E for a shower connected directly to a henley block (completely unfused).
However one thing that raised my eyebrows which i'd like an opinion on is the state of the main earth:
The supply appears to be TN-S with a lead sheathed supply cable. There is evidence of the remains of an earth soldered on to the sheath, but that's broken off and has been replaced with a bit of 10mm into a standard earth clamp as would be used for bonding services.
Is that acceptable? My hunch is not.
If that's the case, and therefore the main supply earth has failed, I presume this is a job for the DNO? What, practically would they do about it?
I suspect their preferred approach would be to convert to PME, but the rest of the bonding doesn't look up to spec at the moment (the fusebox is connected with some 10mm but all the other earth wires (which I presume bond various services - i've not followed them yet) are 6mm which is inadequate for PME.
Any thoughts?
Any thoughts?
