...what do you do?
While re-doing some of the fairly appalling electrics in my house I've noticed that whoever rewired has twisted each section of cable together before tightening up in the terminals.
Now this isn't something I've been doing when I've replaced the cable on the logic that the screw should be good enough to secure both cable ends in the terminals and also because twisting them together could weaken them and cause them to break - possibly inside the sleaving where you wouldn't notice it (especially on the smaller earth core. Obviously testing should pick this up but what if it's weakened but not broken and then decides to give at a later date - you're either left without power or even worse, with a defective earth loop?
Also, is it usual to stick both bits of earth core in the same piece of sleeving? I've been sleeving each core separately.
Just wondering how the pro's do it.
Fred
Fred
