Toilet: Anything between the cistern and the pan
16 Sep 2004
Leeds
Hi
As subject really, do I need to put anything between the toilet cistern and the pan? Is it ok to have porcelain against porcelain?
You need a foam or rubber doughnut to sit between them.
Hi, I have that, it was more between the two porcelains. Should I put some silicone on the pan for the cistern to 'sit' on, or is it ok just to put cistern on the pan with nothing separating them?
HI
cistern simply sits on the pan no silicone is required just rubber doughnut washer not cheap foam washer.
