toilet cistern
18 Feb 2006
hi im having a bit of trouble with the toilet cistern atm. when i flush the toilet and it starts to fill up with water, it then gets to a level and keeps on running with out over flowing and the water runs into the toilet bowl how do i sort this out cheers
more likely to require the ballcock to be stripped and either cleaned out or the washer replaced, sounds as if it is overflowing down through the syphon, very unlikely to be a faulty syphon causing this.
turn off the water and disconnect the valve in the middle (near where the water comes out of) you will see a large washer which sits against the oriface to close the water supply, either the washer will be perished, (try turning it round as a temp fix, or there will be debris stuck in the oriface)
you were spot on kirkgas i did what you said and it was a bit of dirt that was causing the problem its working fine now cheers again
