ALL.
Looking for some advice., I have 2 toilets , one upstairs which is workign ok, one downstairs which is in the outback building and its this one which has a problem.
When you do a normal flush the water level in the bowl is fine and stays teh same, however when you flush solid waste the water level goes down and you can hear a 'sucking' sound, I have to pour water in the bowl to make the level rise again.
The water level does NOT go down over time and stays the same.
Just need some pointers as what the problem could be.
Thanks.
Thanks.
