This is tricky to describe so bear with me please.
My existing toilet cistern on a close coupled loo was attached to a batten holding it 3 CM from the wall because the only way I could fit a soil polypipe to the hole in the floor was to do that.
Basically the centre of the soil pipe in the floor is 100mm from the wall and I'm struggling to find a toilet with the waste exit far enough away from the wall so I can fit a pipe. Even a flexi pipe is too wide a 90 degree bend to fit. I've even tried the space saving pan connector before.
Other than sit the pan and cistern away from the wall I cant see any options. This cant be a new situation so if anyone has any idea I would be grateful. I think the original toilet when we moved in 20 years ago had the waste exit set way back in the pan so they had more flexibility. Modern loos dont seem to have that
