Toilet with very little clearance behind
26 Mar 2010
Worcestershire
We have a cloakroom toilet that we are looking to replace however the distance from the current toilet to the rear wall is very tight with the waste pipe being vertical into the floor (as opposed to going out the wall). Does anyone know a brand of loo that is designed for such small spaces??
Happy to go for high or mid level cisterm if that can reduce the distance between the pan and the wall
Would a space saving pan connector help you out, or are there other problems?
Check out McAlpine plumbing for the best gear around.
John :)
Thanks for the reply, I just have very little space in the room due to the position of the door and that it is used by someone who uses a frame to walk. Need the pan as far back against the wall as I can
A nice slim cistern then....I guess its a case of visiting as many sites or showrooms as you can.
One possibility is having the door open outwards......
John :)
