toilet wont stop running!!!
6 Dec 2010
Merseyside
Hello all my fabulous DIY pals:cool:
those of you who know me will remember I dont actually know how to do ANYTHING!!! :cry:
so please HLEP ME!!!! :( :(
I have a cistern that after flushing starts to run again and wont stop for about half an hour!! :rolleyes:
I have tried pressing the button on the top a few times and sometimes it will stop but now it wont at all!! :confused:
its driving me nuts!!! :cry:
can someone tell me how to fix it please :)
Im pretty good at fixing things if I know how....But I just dont know how!
thank you soooooooooooooooooooooo much ;)
Jelly x
First of all, pop the lid off the top of the cistern. There are usually two main pieces inside. The flush valve (connected to the flush handle / button) and the fill valve (connected to the water supply).
Watch the fill valve as you flush the cistern.
The float should drop as the cistern empties, opening the fill valve. It should rise again as the cistern re-fills, and shut the valve before the water level reaches the overflow standpipe (part of the flush valve).
If the float jams or is out of adjustment, the fill valve won't close, and the excess water runs down the internal overflow into the pan.
If lifting the float by hand closes the fill valve cleanly, try adjusting the float level to close the valve earlier.
If the fill valve continues to run even with the float raised, it's probably time to overhaul or replace the fill valve.
ahhhh tickly
there appears to be another problem!! I cant lift the lid!
I have tried turning the outer ring that is around the two buttons but nothing is happening
dont think I am going to be able to do this one myself am I :rolleyes:
Push one button down and put a small screw driver and lift the other button up and then pull out the first button. Then you should find a large white screw that needs to be undone. Then like magic the lid will come off.
Andy
okey dokey!
will give it a try in the morning cos if I get it wrong I dont want to be stuck all night waiting for an emergency plumber lol lol
will report back tomorrow!!
thanks andy x
