Got called to a neighbors property the other day, They had an EICR a couple of months ago and a new kitchen installed last week. The problem is that when they plug in the hob ignition the main RCD trips(literally just the earth pin on the plug) it turns out that the gas pipe is copper solid pipe. Therefore the gas supply is earthed via bonding so the hob is double earthed with the plug. the socket is ok when used for anything else and ok on the hob when earth wire temporarily disconnected. Can anyone shed any light on it?
