Extending 240v power supply to gas hob
Why? I thought you claimed to be an electrician? Have you really never seen a consumer unit in a kitchen cupboard before?
Why are you advising the isolator should be moved to somewhere accessible? You were telling someone on Thursday not to bother having an isolator at all. Make your mind up :roll:
If you think the location of the cooker switch is bad, you should see the location of the consumer unit - it's in the same cupboard as the cooker switch - you can't tell from the photo but it's a corner unit and the consumer unit is all the way over on the right hand end, about 500 mm over from the door opening.
Unbelievable. I'm speechless.
My in-laws had exactly that arrangement in their late-80s-built bungalow. It was a Wylex Standard CU (main switch on right) and it actually required some acrobatic activity to even reach the Main Switch (after, of course, one had emptied the cupboards)! I presume that it must have been installed before the kitchen was completed, and it was all-but-impossible to work on it once the kitchen was completed- removing the central shelf and 'getting into' the corner cupboard was the only hope! CUs in kitchen cupboards are common enough, but this one was IMO more than a bit ridiculous!
Kind Regards, John
I've never claimed to be an electrician. I've never seen a CU in a kitchen cupboard. I've never said not to have an isolator on a cooker.
An electrician in Wales told me the "worst" location he found was in the bottom of an immovable Welsh dresser. Part of the back of the dresser been removed so the CU meter and cut out could protrude into the bottom cupboard of the dresser.
