- Joined
- 23 Mar 2004
- Messages
- 31
- Reaction score
- 0
- Country
Hi All,
I've had to change the timeswitch on my boiler.
I had a danfoss randall 3020p and have bought a SET2E to replace it.
It's a gravity fed system with a pump, 3 wire room thermostat and the boiler.
I've wired it up but can only do so in a temprary fashion (i.e. to test it) using a couple of connector blocks. This is because the neutral terminal is too small for the 4 neutral wires I have to connect to it.
The four neutrals are : the supply, the pump, the boiler and the stat.
I'm reluctant to use a JB or terminal blocks as a permanent installation, but can not see any other way to do this. If I did use a JB/terminal it would mean just 1 wire running to the N terminal of the timeswitch.
What is standard practice in this situation? I realise, given the 3 amp limit from the fused spur that it will probably be ok to do that, but is it the right way?
Thanks in advance...
David.
David.
