I haven't read any legislation that requires that.ChrisR said:Don't all electrical works have to tested for full compliance with regs though?
Yes, I'm with you on that, and I'm not encouraging you to do anything you believe is risky or that you're uncomfortable with. I'm just observing that you're competent, and that you know how to replace like with like, and you can arrange for testing, of whatever is necessary, to be carried out when the professionals get back from the beach on Tuesday.I've got a megger and a dvm but I know enough to know that I don't know what I need to know..
Softus said:The Wiring Regs document is the de-facto standard for safe installations, so religious adherence to it is a way of demonstrating safeness, but not the only way.
It's just entrenched arrogance.ricicle said:It's quite strange really as the regs are non-statutory, but if you read inside they say that all electrical installations (apart from specialist installations, off-shore, mines etc) must comply with them.
Unless it says otherwise, which I haven't found, the only reasonable application of that SI is to premises, not to an abode.Spark123 said:As an act of work it will fall into the scope of the Electricity at Work Regs.
I can't find the place where it defines this onus - can you help?Unlike most Statutory Instruments, if you are charged with violating an absolute regulation the onus is put on the accused to prove they have complied.
No. The fact that the person is an employee, or a self-employed person, is irrelevant.Spark123 said:If an employee was to leave a dangerous situation by their act or ommision then I'd have thought these regulations will stand, as part of their work they have not complied with the said act.
Leaving behind a hazard would be, if the result of simple human error, a tort of negligence, or, if incompetence, then, in some circumstances, an act of criminal negligence.
I very much doubt it.IJWS15 said:Almost certainly a breach of the Health & Safety at Work Act 1974 if they are working (duty to the public as well as employees/workmates etc).
ChrisR said:Anyway, it has come out that the cable at ground level is some sort of nasty old rubbery stuff.
