Touch plate connections
12 Mar 2011
Lancashire
Can anyone tell me which connections go together? I'm after the equivalent to common, L1, L2 for each gang. Whoever put this old touch plate on has left a mess and without pulling up floor boards etc to get to the junction box it is proving difficult. Cheers
The advice you need depends what you want to do.
Do you want to change the switch for something else or just tidy up what is there.
Hamilton Litestat (R.Hamilton & Co Ltd) T: 01747 860088 should be able to provide a data sheet for the devices.
I'm looking to change it to a normal rocker switch. There just seems far too many wires for the switches. There are only 2 lights even though it's a 3 gang and that's why I can't easily figure out what goes where.
Does it work, if so what does or did it do.
was any of it two way using SLAVES at the other switch
Looks to me like it has
Live and loop feed in TERMS 1
a dimmed output TERM 2
a dimmed output TERM 5
a switched output TERM S3
The far right one works but the middle and left don't. That's why it's hard working out what goes where as you can't use a multimeter on it easily. :mad:
The right one works fine although it is switching itself on and off!!
Under normal circumstances that would be fine and as you say, easy to do but for some unknown reason the 3rd gang has a wire going to it yet there isn't a third light. This master socket seems to be wired up weird. It may even have the live feeding from the 1st gang to the 2nd gang at the switch rather than the ceiling rose or a junction box.
I've identified the live for one, but was trying to identify what connection did what. Cheers
That doesn't matter, you can still find out which conductors are permanently live.
Yes.
If your lighting circuit is wired with the live loop running through the switches then a lot of the connections at this one could make sense.
Hence identifying permanent live(s). This is important.
How are other switches wired?
It's quite likely there's the right number going to the switch. Ignore the links, and you have 4 conductors, either live loop in and out, and two switched outputs, or two normal switch drops. Brown & red would be odd for the latter though. How's the lighting circuit wired? Singles in conduit?
Does it look as though a 4-gang could fit on the same sized place? There's a pair of tunnels with no terminals in them.
Might be worth pressing Hamilton - surely somebody there must know how it is connected? Companies like that may make cosmetic changes to products all the time, but often the works soldier on for years.
If I had to start trying to divine how it is connected, I'd find the permanent live(s) and temporarily put a 3-gang switch in and see what it did.
My guess is that the 1 terminals are for the live feed (and that if you were to remove the connection between them some of your lighting circuit would die), and the 3 (potentially 4) gangs are numbered 2, 3, 4 (missing) & 5, and each gang has a dimmed output and a slave link.
Why the outputs from 2 & 5 are linked IHNI, nor why S3 has a conductor but not 3. Is that the gang which doesn't work? To your knowledge has it ever worked?
It may be that there is redundant wiring for a third light (maybe a wall light) somewhere and they have parked the switchwire for it in a disused terminal.
Or a terminal intended for connection to a slave?
I did wonder that too, but that looks like an 80's dimmer and i dont recall slave units about then, but i have vaque memories of early touch dimmers that had a dimmed output as well as a fixed output for each gang, i recall it was to switch non dimmable loads like fleurescent in conjuction with dimmed tungsten loads
course as you say i may be wrong, hence MASTER being on the dimmer
