Cheers guys, going to try a combination of the two! get a long screw into the lintel and patch the hole with morter.
Curtain pole will outlast the house at this rate!
Well, put it up last night, cut out the loose plaster and got two long screws into the lintel, which was only thin, so no strength parallel to the wall at all, but they were stuck in well, so very strong perpendicular to the wall, packed in around the screws with morter, which gave me the parallel strength, and skimmed over the top to neaten things up, seems set like a rock this morning, reckon I can swing on it, and thats quite a test let me tell you!
Cheers for the advice, worked a treat!
Nestor,
Cheers, I did consider that, but problem started last time when the action of drilling shook loose the filled area.
However, I guess if the patch had been put in properly, it wouldn't have come out
It rock hard anyway, going nowhere, so I am a happy camper, as it's my housewarming this weekend and about 7 hungover people are going to be very pleased at 7am that I managed to get curtains up in that room
