Towel rad slow leak - boiler pressure dropping.
Is it possible to fix the valve without draining down the rad, which is a pain and time consuming? I know there's loads of videos on YouTube etc but most are on there to make money and make it look too easy. Would prefer a pro's advise and how to do it please and if any pictures added would be a bonus. At present, as soon as I turn the valve nut slightly it immediately starts to drip quite bad and then drops the pressure so I've finger turned it a few mil and it's stopped.
I could drain everything down again but it's a bit nippy.
Thanks for any help.
You could use a pipe freezing kit on the pipe feeding the valve, but even then you'll need to turn off the valve at the other end of the radiator and drain the radiator itself. Otherwise, the surprising amount of water held in the radiator will drench you and the surroundings, whether you change the whole valve or just its innards.
Ok, thanks Chris. How can I tell if it's the packing nut? Reason for asking is you can fix it without draining down?
