Towel rad slow leak - boiler pressure dropping.
14 Oct 2025
Hi guys,
Require a bit of help please to replace this part that looks oxidized. It only drips a tiny amount when the heating is on and it's green for some odd reason. Can someone provide a pic of the part I need to replace it as it looks different to a normal convention rad.
Thanks for your reply. I have searched for rad valves and can't seem to find the one required, all come up with normal rad valves.
that green crust is just copper verdigris where water's been weeping out past the valve tail and evaporating mate. because it's only dripping when hot the pipe expands and lets a tiny weep out, but it's definitely enough to drop your system pressure over a week or two. usually it's just the ptfe tape or the rubber o-ring on the 15mm tail that needs re-sealing into the bottom of the rail, half hour job to drain down and sort.
Right, ok so I'll buy a new 15mm valve and screw the head off of it and replace the one that's leaking. I am going to do this live without draining down so I don't lose a lot of water. Should only take a few seconds. I'll drop the pressure in the rad and let the heating cool down prior. The pressure on the boiler is dropping down as soon as the heating is off so a possible boiler leak but that's for the service guy to investigate. Don't think the towel rail is the cause of the pressure dropping
You might need some swimming gear and a big towel!
Seriously though, drain the system below the level of the valve before taking it off.
Hi, so you're advising to drain the whole system down for one upstairs towel rad? Am I right in thinking, if I close off all the rad valves upstairs and down then there is only going to be water in the pipe work and the rad I'm working on?
I've always swapped the entire valve.
I guess if you can find a match you could swap just the corroded part but you are already dealing with having to cut the water off to enable a swap, so take a few more minutes and put on a new valve.
If you don't have much experience with DIY plumbing then get a local plumber to do it.
It's a risk getting to the point of swapping part only to find it don't fit.
So two things:
No, I didn't advise you to drain down the whole system - maybe read my post again.
.. and I'm not a plumber, so feel free to ignore my suggestions...
