towel rail with microbore
2 Aug 2006
Merseyside
Can anyone give the procedure for fitting a modern towell rail in a bathroom to an existing microbore system with one twin valve on the rad, the pipes come straight up from under the floor and into the twin valve. any help would be appreciated :?
The procedure it to do whatever's necessary to get the pipes to the valves on the new towel rail... erm... which part of that..?
I couldn't work out how to answer that one either, short of writing several pages.
Bit baffled meself..wasn`t going to take the chance....
8/10mm x15 reducer from each micro. pipe to a length of 15mm pipe and fittings as necessary to connect to each end of T/rail via rad valve ....t.r.v. not necessary
