- Joined
- 17 Oct 2005
- Messages
- 22
- Reaction score
- 0
- Country
I have just moved into a new flat. There are the central heating pipes coming up from the floor and these have angled radiator valves. I want to install a towel rail ,without draining the system, but most seem to require fitting straight valves. The distance from the end of each valve is 36.4cm which is smaller than the distance between the valves on most towel rails (40 ar 45cm). Is there any way to attached some kind of fitting that will allow me to install a towel rail that takes the water in and expels it from the bottom???????
