W
Woodendhead
While looking into where I could (or get a spark to) put a spur in for a TV loft amp, I discovered the logical point for an existing spur looks like it is part of a ring main or what I fear is spur on a spur.
Now I am beginning to worry about the wiring in this place.
I know how to confirm if it is a ring or the dreaded spur on a spur unless I have a damaged cable / broken ring, but any ideas on tracing the spur.
Also in my investigation I have found another spur I have no idea where this runs to, but as of tonight I do know it is not the known spur as I know they are on different rings. I had though I have traced the spur but no. Hence I am getting a bit worried.
The suspect spur on spur from the end I know about runs up into the between floors space, the socket that could be the is in the room / wall directly above hence my suspicions. The other runs down into the same space on the landing.
What I am not going to get away with is pulling floorboards up to trace these.
Thanks in advance for any ideas.
