Tracing / fixing a damaged spur
I'd prefer to call it fact gathering.
Or detective work.
I'd prefer to call it fact gathering. ... Or detective work.
In a similar position, that's probably what I would call it :)
Following sparkright's very valid comment about sheath colours, I think a crucial question is that of the sheath colour of the (brown+blue cores) cable supplying the socket of interest. If, as one would expect, it is grey, than that discounts any of the white-sheathed cables in the roof space that we have so far seen (unless one changes sheath colour at a hidden JB/whatever!).
Kind Regards, .John
Thank you everyone for your suggestions! I will need to investigate properly but may not get a chance to do that during the working week. My other half is away at the moment, and it probably will take two of us to move stuff out of the way in the loft to find out what is going on (and also get some decent light up there etc.).
Have not read every single post, but what I would do is first open the CU(s) and see if there are any harmonised cables in there.
Then I would turn all the circuits off and re-energise them one by one until my mystery outlet comes live. Then I would check if that circuit were a radial.
I would check to see how many conductors were connected to the breaker, be it a radial or ring final.
It could be an additional cable was fed from the CU to the faulty accessory, or to a point unknown from where the old cable was extended with H to its current position.
Another (rare) possibility is that (if the socket is fed from a ring final), there could be two breaks in the N at adjacent accessories (or the N element of a leg has been deliberately disconnected due to a problem) and the faulty point was tapped off this leg with a JB.
Picture the scenario. Attached to that spur is a faulty appliance.
Spark gets called to RCD trip fault. Cannot locate faulty equipment but isolates a bad reading neutral between two sockets which he disconnects.
I suppose powering down and connecting L & E together at the faulty accessory would give you an idea where the broken cable was connected to on the ring. Disconnect all the sockets and put the DMM on each leg to find the deliberately introduced LE short.
