Transformers in a bathroom cupboard
17 Oct 2006
Yorkshire
Can I put 24v transformers for electric blinds and lighting in my bathroom cupboard?
Do I then have to fit a false back and make it only accessable with tools?
Does everything have to use fused cable outlets for the mains supply?
where is this cupboard exactly?
is it part of the building structure or just screwwed to a wall? ( IE an airing cupboard? )
can you reach into this cupboard while standing in the bath?
if your bath panels screw in place then under the bath is technically not in the bathroom... :shock:
The cupboard occupies an entire wall floor to ceiling and is effectively built in as various pipes run through it. It also contains a radiator. You can't reach it from the bath.
has a door and handle? of a reasonable depth and size?
if so then it's not in the bathroom.. it's a seperate room..
many an immersion heater and shower controlls are located in airing cupboards whose doors open into the bathroom...
