As I'm sure you are aware, almost all such discussions result from the behaviour of just one member, who makes his point about the word "transformer" (or sometimes "nominal voltage") on every possible occasion, in innumerable threads. If he could be persuaded or forced to stop doing that, I think you would find that all such discussions would immediately vanish.Repeated discussions for the sake of pedantry regarding the merits of what is or is not a transformer are adding nothing to the multiple threads they are posted on.
What a carp definition.
Yeah, I was taught that at college. Strictly that a battery is two or more cells connected together. If there was only one it was called a cell.Interesting - a battery always used to be an assembly of multiple cells. My dictionary must be out of date.
As I've said before, definitions follow usage, not the other way around, so let's be sensible with usage. (But since the definition of transformer is already "A device consisting of two or more inductively coupled windings" I don't see the quandry...)It's not simple for some. It would be if it were agreed that definitions require updating.
Precisely, but you're only applying that to one of the examples.As I've said before, definitions follow usage, not the other way around. So let's be sensible with usage. Simples!
As Himmagin so often likes to remind us "if it looks like a duck, and walks like a duck..." An electric car looks like a car, walks like a car... An SMPS does not look like a transformer, nor walks like a transformer...Precisely, but you're only applying that to one of the examples.
A transistor 'transforms' voltage, as does a resitive divider, or an optocoupler, or many other components. You're confusing the verb with the noun.It doesn't look like the original type but it "transforms" voltage so how simples do you want?
