It is not a zoned area as it is more than 60cm away from the bath tub and other sources of water. If anything, it might turn out to be a Zone2 at worst.
Thanks. The wall thickness is the thickness of brick plus 70mm cavity and then thickness of the other brick. So altogether about 250mm overall depth. It is to be fitted to a new bathroom and currently there is no holes. So all will need to be drilled. Can the above model be fitted to my bathroom then or is the thickness is too much?
From dimensions, it seems the backend is only 80mm deep. So does it mean I will need to fit a ducting to the back of it or will it not work?
250mm is fine; I was asking in case it had to go to the other side of the building with lots of bends.
Normally you get a fan, a short length of duct, and an external vent. They may come in a kit together or you may buy them separately.
