Can any one help!
i've currently got a pumped cental heating system with a gravity hot supply to the hot water cylinder. The boiler is oil fired, with a pump inside the casing.
How can I convert the pipe work, so it is a fully pumped system.
At present there are four pipes coming from the boiler. Two are the flow and return from the central heating, the other two go to the hot water cylinder. There are no valves on the system, no cylinder thermostat or room thermostat!!
There is a feed pipe from the feed and expansion tank in the loft and a vent pipe to it.
any help would be appreciated
