off course the next question would be "what tools do you have" keeping in mind the likly answer will be a handsaw/jigsaw/other basic tools as anyone with a router would tend to know the answer without askingIf it were me (with only very basic carpentry skills) I'd probably use a router.
point off noteJigsaw
Good point of note.point off note
with only 3mm to try and trim it will be almost impossible as the bottom off the blade will almost 100% defect off the surface and just skim across
my suggestion it aim the jigsaw at a minimum say 20 degrees in to the face and cut in till all teeth are a minimum 1.5mm into the surface then work round toward to a strait run at 6mm off line as this will give at least 4 or 5mm off timber [chipboard]on the open side off the blade otherwise as i said abouve it probably wont work
if you can only remove 3mm then you need to add timber to the open face to hold the face timber [or chipboard crumbs]you are cutting off to guide the blade
you will need a batton screwed on the open face at at least 3 points with an entry point for the jigsaw blade formed off a slot or drill hole that needs to be covered by the hob
then as you jigsaw remove screws and replace as you go to allow the blade to pass
