Triton Jade II: water too hot!
4 Apr 2009
Huntingdonshire
the water that's coming out of our electric shower (triton jade 2) is really too hot, whatever the setting on the main dial. We used to be able to control the temperature much more...
The problem really is that the dial does not change anything to the temperature. So the water is too hot when the shower is at high power, or too cold when the power is on economy.
Thanks for any comment!
J
Thanks for your reply.
I actually thought the same first. So I removed the cover and then was a bit discouraged... The inside looks neat and tidy and I was not sure I could really dismantle the shower safely...
What would you start with? The inlet? Is it a good idea to open the heater can?
if you can
ive known them restrict the outlet with scale that has flaked off the elements
you can sometimes get away with back flushing them
another point to check is the inlet filter :idea:
Ok. I tried the shower without the head and at first, I had a few black bits coming out, but nothing alarming. The temperature was actually as it used to be (we had the shower for two years now): cold but good pressure from 0 to 3-4, and hot but very low flow above 6.
Now, I can try to descale the showerhead but it does not look that much encrusted.
I will also check the inlet.
Thanks.
quick update: the limescale on the showerhead was actually enough to completely change the behaviour of the shower. After a good cleaning (just a few holes were blocked really), the temperature is back to normal...
Thank you all.
J
