Turning Internal Doors around ??
4 Dec 2006
Kent
Hi Folks.
I've had a couple of my internal doors re-hung opening outwards. The guy has put a new doorstops on & suggested i fill where the previous hinges were. I have bought some "Ronseal Multi Purpose Wood Filler" but i dont really know where to start :scratch: . Any advice would be appreciated
I've attached picture
not quite a door stop :wink:
you should have either installed a door stop of 12x18mm or there abouts
or used a wider bit of wood cut flush
hardboard and normal polyfilla would have done
any way fill in the large holes a layer at a time [around 3mm ] sometimes quicker to glue in wood fill and sand down
You can use isopon p38 car body filler and build it up in layers, this has the advantage of curing (to the point of being sanded) in about 20mins so you can get the job done in a day.
