TV coax cable
17 Apr 2007
Having recently installed a new 12db gain aerial in the loft, I get around 85% signal and 100% quality yet the TV still gets pixelation.
The cable in the loft and TV socket in the g floor room were already installed when I move in early 2022 so presumably installed when the house was built in 2003/04.
The cable is marked 'pro-power 75ohm low loss coax' but it does not have a shielding foil under the outer metal braiding.
Is the cable acceptable for Freeview?
full
To be fair, it's not the best - it has limited screening ability, and so might well pick up all sorts of RF noise, such as thermostat clicks, anything switching. Modern coax would be much better, such as CT100, but there is more modern than that FP100 I think.
It might be cheaper bought by the full coil, than by the metre.
You have low loss coax with pretty poor braided screening. ProPower seem to be a CPC/Farnell own label brand? Their website is not playing ball so I can't tell if all copper or nastier stuff.
It'll likely work OK unless running near other things that produce interference, when the lack of screening will become a big issue.
CT 100 was dreadful stuff... Air spaced. No longer made. Other brands use the CT100 name for some really dreadful coax. Avoid!
Webro WF100, Philex (spit) PF100, Triax TX100 are known brands. All copper core, braid and foil are the key with foam core dielectric.
Did you use a compass to check direction is accurate , can be difficult in a loft .
I got a screenshot of google map, marking a line between the transmitter and my street then zoomed into my street and copied and pasted part of the drawn line to get the angle - about 10° anticlockwise from the apex of the house roof.
Signals can bounce off things, I have had an aerial pointing at a building 180 degrees from the transmitter where it was clearly bouncing off the building. If bounced signal is better than direct it can mess things up.
Old house aerial had to be low down on garage so it picked up Moel-y-parc and not Winter Hill, if it could get both, the TV would keep retuning its self.
Those numbers are good. Do you always see those numbers, or do they vary?
Do you see the pixelation on all channels? What sort of pixelation is it? Do you see less pixelation viewing the same channels elsewhere?
Our most used TV, in the living room, due to our high location, constantly flagged up new channels, and the need to retune. We get a good signal from our main area transmitter, but useable ones from two other area, main transmitters. The solution, was to buy and fit a dropper in the antenna lead, at the back of the set.
You can get transmitters position and use phone app compass to get direction spot on.
5G check out the free filter supply of them for likelihood of mobile pole/tower locally:
NEW aerials may / should already be filtered group K...
Too much signal can cause overload and pixellation in the same way as too little.
Very nearby postcode of a shop, pub, church, school etc.,. will allow field strength prediction tool to estimate.
Roof losses typically balance out the 12dB aerial gain (is that dBi or dBd? theoretical isotopic radiator or a real dipole?). and TV receivers need between 45 & 65 dBuV ideally... So signal level at the location matters!
Yes, the pixelation is across all channels when it happens, even with good signal.
Having given it some thought, the cable I mentioned runs down in the wall from the attic to the the g floor room. The wall is the divider between mine and next door. The houses are wood construction and next door's electronic gadgetry could well be causing the bother.
I'll experiment with a WF100 cable routed from the attic, down the staircase direct to the TV.
What's the general opinion of this RG6 cable product offering?
Its states
  • 1mm solid copper coated steel conductor
  • 64 x .12mm aluminium braid
  • Foam dielectric
  • Aluminium foil shielding
  • PVC Sheath
  • Overall diameter 6.4mm
  • Nominal attenuation @ 1MHz = 2.82dB
  • 75 Ohm
