Two gang light switch - what am I doing wrong?
26 Sep 2025
When I wire what I believe is the live to a switch with the neutral, one light works but other one doesn't.
When I wire it like this, nighter work.
What am I doing wrong?
Try the 3 lives together as suggested but these may be switched lines rather than neutrals.
What makes you believe that is the perm live?
If you put the 3 browns together do both lights work?
Faulty switch maybe?
They don't work if I do that.
When I disconnect the switch and separate the 3 sets of wires. One marked perm live shows it has power
When I connect these two wires to a plug/ socket that light works. But I can't seem to make it work in the switch.
There are 3 wires in the light - super confused
How do you mean, it works?
Do you mean you are extending that twin and earth cable pictured in the switch box and connecting in to a power supply and the lamp in the pendant lights up?
Are you sure the neutrals are all making continuity with each other in that connector?
