I have a two way light and want to replace one switch with a dimmer switch but obviously still leave it two-wayed. Can this be done, and if so how does one go about it?
1) With a 2-way dimmer switch at one end, and a normal switch at the other. The drawback is that you can only adjust the level from one end, so if you turn it on at the switch, and it's not the right brightness, you have to go to the dimmer to change it.
2) With a master-slave dimmer, so that you have full dimming control from each location. The drawback here is the cost...
