hi Guys,
i have recently moved a two way switch across the other side of the room, they now only work if the downstairs light is switched on first, it is basically a standard set up with the stairway light one switch at the bottom one at the top. now i always assumed you needed three core and earth for this but apparently not. i have i believe the old way of wiring two way sockets. i fully understand how to convert from one way to two way using three core and earth but how can integrate it into this system, because the cables runs and boxes are plastered in so i cant do a new cable run, basically i have three wires at both switches downstairs i have a single neutral (not tagged so this doesn't help) and the usual red black and unsleeved earth and upstairs i have a single red and the red black and unsleeved earth, testing the cables it seems that both switch sides as they should in two way mode, i,e the live then the neutral both carry the voltage, but i am struggling to find the feed cable help me please!!!
