U value of 100mm cavity wall versus 150mm External wall insulation on a 140mm block wall.
21 Jul 2004
Does anyone know what U value is for 140mm concrete block work with 150mm external wall insulation?
Is this better insulation wise than a standard cavity wall with 100mm insulation?
As above, depends entirely on the type of blocks, insulation etc. EWI is normally polystyrene and 150mm would give a u-value of about 0.25...ish. Cavity walls could give you anywhere between 0.15 and 0.25 depending on the materials. What is it for?
