UFOs
Actually I have not demanded anyone to explain what it is - you are the the one that keeps insisting its a lens flare and yet are unable to post a single photo from google that looks anything like what is seen in the vid - it should be really easy.
I have told you what I think it is I have suggested it could be a separation plume or a solid physical object - a UFO in the sense that it is an Unidentified flying object - although you will probably argue the toz for 15 pages over the word "flying" but if you think that things "hover" in space then maybe flying in space is ok.
You are being trolled. Ignore him
I've said what I think it is and you disagree, you haven't said what you think it is. You've listened possibilities.
I think you must be on some sort of neurodivergent scale. I keep saying that I think It is a solid physical object. Hovering /floating / orbiting/dangling on a piece of string.
A solid object, but one that was invisible from the ground and presumably from radar.
Did you ever work out how large it was or why it was floating over Florida?
You think that is more likely than a lens flare?
Actually that could be the jellyfish after all, I'd miscalculated the location to be further away than the launch site. It would also explain why no one saw it from earth.
Funny isn’t it all noseits posts were just mocking - nothing to add to the conversation - not thoughts of his own to what it could be and then as soon as I said "no one else thinks its a lens flare" to minions post - up he pops saying he thinks it is lens flare. :rolleyes:
As opposed to those that have neither the wit, or the nous to look beyond the numb-of-mind, goto term 'UFO'.
I'll stick with Minion, at least he writes with joined up thinking. :cool:
Yes or maybe not because if you want to attach a conspiracy to it then yes clearly seen on radar - ignored because they know all about it and or its one of ours.
No but it looks like it is casting its own shadow upon itself which makes it look enormous. Or it could be a case of this.
Yes - lens flares do not slowly peep into view from behind something. - Its not a lens flare its a solid object.
