Yes it would minimise it - but would introduce (or rather, exacerbate) other problems such as the economics of having near 100% standby that was rarely (if ever) actually used.Sure, but if one reached the situation of "more-often-than-not 'work out' reasonably well" in relation to, say, renewables, that would minimise the amount of flexible generation by other means (and/or storage) that was needed to 'fill in the gaps' and turn it into a "reliable" supply.
A very long time past our lifetimes - the reality is that there is still a lot of fossil fuel still in the ground. I can recall when I was at school hearing the doom-mongers saying that oil was running out - and if they'd been correct we'd have run out a decade or two ago, but I think we can all agree they were wrong. What they forgot to factor in is that the business case of looking for and extracting more oil depends on price, and if it looks like we're heading for an oil shortage, then that business case changes in favour of more exploration & extraction.It's all very well saying "would not be sufficient", and I can understand the thinking behind your statement, but once (beyond our lifetimes), all fossil fuels (and, I suppose, trees etc.!) are exhausted, what alternatives will there be beyond 'renewables' and nuclear?
I've heard it said that we have in excess of a couple of centuries of coal still in the ground in the UK alone.
That is in fact one avenue being investigated by various groups - though IIRC there are other methods of doing the water+lecky->hydrogen conversion than electrolysis. A few years ago I went to a talk about a project that would take hydrogen plus atmospheric CO2 and make methanol. That is far more useful than hydrogen since it's actually practical to store and use it in large amounts. Even if it were only used to displace oil from mobile power (mostly transport) requirements, it would make a massive impact on CO2 emissions. The major benefit as a mobile fuel is how it can be moved, stored, and dispensed using all the same infrastructure that we currently use for oil derived products - and burned in existing engines that could still run on petrol/diesel. By comparison hydrogen comes into the "what ****ing idiot thinks that is a good idea" - which seems to be why politicians are wedded to itHowever, what about using nuclear-generated electricity to produce burnable gas or liquid fuels? The simplest, and 'cleanest' variant of that would presumably be to use the electricity to generate hydrogen by electrolysis of water - and that would have zero impact on global resources, since burning the hydrogen would regenerate the same amount of water as had been used to create it.
Indeed. And I think we can all imagine the anti campaigning from a different (but probably overlapping) group of green campaigners if any new scheme were to be proposedI agree with the larger lake, but where in the UK could you build that? To be worthwhile, it has to have a suitable head / height.
As an aside, over a century ago the City of Manchester Corporation set out to find an alternative water supply - the city was running short at times, and the "brown" water they were getting from some peaty areas was not suitable for the textile industry. Thirlmere was chosen because of several factors - a large surface are meant a lot of storage for a given change in water level, it had enough elevation to get the water to Manchester without pumping, and the properties affected were of relatively low financial value compared with (say) the likes of Windermere which was already seeing the value of lakeside property getting quite high
