It doesn't.Personally, I can't see where it addresses 753.411.3.2
This is untrue:
What if you go and get them yourself - not delivered?753.411.3.2 says where the heating units are delivered without suitable conductive covering.
Of course it does.If you don't understand why I keep saying it, you can't fully understand what I'm saying - so perhaps I'm not being clear enough. What I'm trying to say is that (ignoring stillp's theoretical argument), the equipment itself cannot become any less safe by virtue of the touchable parts being earthed.
Not because it is electrical, that is true, but because you have earthed it.You and I may feel that the environment would become less safe as a consequence of unnecessarily increasing the amount of earthed metal around - but that would be just as true if we were talking about baths, metal shelves or a metal tool cabinet - it's nothing to do with the equipment in question being 'electrical'.
I agree. The equipment itself cannot become any less safe, but the environment it's in may become so. But, the distinction is so fine that in practical terms there is no difference.What I'm trying to say is that (ignoring stillp's theoretical argument), the equipment itself cannot become any less safe by virtue of the touchable parts being earthed.
Why ?I have mentioned it before but there are Class II 12V lights which use the metal bodywork as the return path for the 12V.
I presume "must not" would be appropriate for this.
I am not 'arguing for it'. As you know, I wouldn't do it. However, I am saying that I'm not sure that there is any real basis for manufdacturer's saying that it "Must not be earthed". We seem agreed that that statement is nothing to do with the electrical functioning (or electrical safety) of the item itself, and that the only apparent justification is that by not earthing it one is making the environment slightly safer. However, the same is true of all thsoe baths, metal shelves, metal cabinets, metal window frames etc. etc., and I cannot recall any manufacturer of such products stating that they "Must not be earthed"!Not by the workings of that equipment, no - but because of other occurrences.
Is that not the same difference? Like saying you aren't more likely to drown because of unnecessarily earthing a bath - but as it makes it environmentally (electrically) less safe, why argue for it?
Only if it were being used in a manner/location in which PELV would not be acceptable (regulatory-wise). Otherwise, the arguments above would still apply.I have mentioned it before but there are Class II 12V lights which use the metal bodywork as the return path for the 12V. I presume "must not" would be appropriate for this.
OK, I'm not going to argue about the semantics - I would say that it is the environment that becomes less safe, rather than the equipment, but there's nothing to be gained by arguing about the words.If you earth a bath it is the bath which has become less safe. If you earth metal shelves it is the metal shelves which have become less safe. If you earth a metal tool cabinet it is the metal tool cabinet which has become less safe. If you earth a Class II item it is the Class II item which has become less safe.
... but they did say follow the manufacturer's instructions - probably why the manufacturer states it.Maybe I've missed it, but I have not seen anything in BS7671 which prohibits the earthing of any exposed parts of Class II equipment which are made of conductive materials.
If that's the case, then the manufacturer must have some reason for stating it. If it really were simply because (as you, BAS, myself and others believe) it is desirable to avoid 'unnecessarily earthing' anything, if the same manufacturer manufactured metal baths, shelves, cabinets or what ever, do you really believe that they would include "Must not be earthed" in their instructions??? I think not - which, as I said, implies to me that they have the (IMO mistaken) belief that there is a reason for saying "Must not be earthed" which is specific to (Class II) electrical equipment.... but they did say follow the manufacturer's instructions - probably why the manufacturer states it.Maybe I've missed it, but I have not seen anything in BS7671 which prohibits the earthing of any exposed parts of Class II equipment which are made of conductive materials.
You would need to ask the authors of the OSG about that!Why does the OSG say that plastic pipes "do not require bonding" instead of pointing out that it is not possible and if you do it you are an idiot.
I presume it is because people are used to earthing metal parts of appliances and instead of a lengthy explanation of the reasons simply state "must not be" earthed.If that's the case, then the manufacturer must have some reason for stating it. If it really were simply because (as you, BAS, myself and others believe) it is desirable to avoid 'unnecessarily earthing' anything, if the same manufacturer manufactured metal baths, shelves, cabinets or what ever, do you really believe that they would include "Must not be earthed" in their instructions??? I think not - which, as I said, implies to me that they have the (IMO mistaken) belief that there is a reason for saying "Must not be earthed" which is specific to (Class II) electrical equipment.
Then you needed to ask the authors of BS7671 why the don't prohibit and all the manufacturers why they do.You would need to ask the authors of the OSG about that!Why does the OSG say that plastic pipes "do not require bonding" instead of pointing out that it is not possible and if you do it you are an idiot.
Maybe, but it's the "Must" that I think is a little inappropriate, particularly given that there is seemingly no regulatory basis for it. As we know, there are situations in which some people would advocate earthing things which you and I would feel were better ('safer') not earthed - so it's not 'black and white'.I presume it is because people are used to earthing metal parts of appliances and instead of a lengthy explanation of the reasons simply state "must not be" earthed.
As for BS7671, it does not really say anything about avoidance of 'unnecessarily earthing' things that don't need to be earthed. You've already commented that manufacturers cannot 'prohibit' but, as for the reason why they (often, not always) say "Must not...", I continue to suspect that they are under the mistaken belief that they are reflecting 'regulations' (BS7671 or otherwise).Then you needed to ask the authors of BS7671 why the don't prohibit and all the manufacturers why they do.
What nonsense! There is no such thing (in this context) as "CE approval". Have they declared any particular "British, European and International standards" with which the product is claimed to conform?Response from the manufacturer:
Thank you for your email, the 200w/m2 heat film system does not have an earth and is double insulated and CE approved to meet British, European and International standards.
The film would not work with an earth cable as it works on radiant heat technology.
Which is probably nothing more than "we've always done it that way". There's probably been some folklore at some point saying that Class II equipment must not be earthed*, and the manufacturer's have just followed that line and seen no reason to change it. Lets face it, there's no real reason that an extractor fan "must" have an isolator (good reasons why it's useful, but no "must") yet I can't recall seeing any instructions without this mandatory.If that's the case, then the manufacturer must have some reason for stating it.
What situations do you envisage where it would NOT be a good reason NOT to earth it?* And indeed, there are some good reasons, in many situations, for not earthing it.
Perhaps they know it is safer not to earth it otherwise there is no point going to the trouble of making it Class II.If that's the case, then the manufacturer must have some reason for stating it.
